Model Number: ST39102FC
Ok what do you want to know? These drives can be purchased on ebay for <20 bucks. But you are going to need alot of other stuff before you get this baby up and running and if you just want to get this one drive working it is not worth your while. I have 4 of these drives cousin's the ST39103FC's.
What you will need bare minimum
tcard $50.00
HBA ( qlogic 2100 or simular) $50.00 to $100.00
HSSDC to db9 cable $15.00 to $30.00
This drive is going to test out on HDD tach at around 27,000 max read with an average of 22,000. it will give you a better access time around 8.8 ms(actual) than any IDE drive out there. But, you are better off getting a new IDE drive for what it will cost you to buy the hardware required to make this work.
Isn't scsi better than ide?
Not when you are comparing a SCSI drive of 2-3 generations ago to the current crop of IDE drives. SCSI drives do scale better then IDE drives when used in multiple drive RAID configurations. Now if you wanted to use 4 of these drives and stripe them all RAID 0 for a fast scratch drive then it becomes a little more reasonable cost wise as you still only need one controller and one cable, only the cost of additional tcards are neccesary ( one for each drive ).
As for the sun drive thing, that is merly the firmware installed on your drive, and for the most part Sun firmware is nothing much more than standard Seagate firmware with the SUN monikor placed on it. You can upgrade the firmware, I won't go into that now unless you decide you want to use this drive.
If you are still interested in installing your OS on a FC-AL drive, you are much better off going with a drive like this <A HREF="http://here" target="_new">http://www.seagate.com/cda/products/discsales/enterprise/family/0,1086,327,00.html</A> which is newer and much faster and will run you in the neighorhood of $140.00
It's not what they tell you, its what they don't tell you!
