G
Guest
Guest
I am currently working with a computer setup that has a 36 gig Quantum Atlas SCSI HD and a 80 gig IDE Hard Drive. I am trying to get win2k on my SCSI drive but when i installed onto it and tried to boot off it it gives me an error that 'ntoskrnl.exe is damaged or missing' and that I need to reinstall it. So first of all if this error can be fixed it should solve my problems, but secondly, i cant format the SCSI drive now. When I try to format it from the Windows 2000 CD it says that the SCSI Chain is terminated improperly or not at all or something, but the thing is there is only a Hard Drive and a DVD Player, and they are on different cables connected to the same SCSI Card. The DVD Player uses the bigger SCSI Slot and the Hard Drive uses the Smaller one. Well anyways. I got windows to install on my IDE Hard drive and I can startup with it but when I try using either Partition Magic or the built-in Windows functions to format the SCSI drive it says I cant do it. Basically I need to figure out how to get my scsi drive back to ground zero so I can get a clean install of windows on it, or else just to fix up the ntoskrnl.exe. If anyone can help please do Thanks
BiGBOi
souljabigz@hotmail.com
BiGBOi
