Closed
Help with chosing a Graphics card
February 2, 2013 6:12:04 AM
I need a graphics card which can play games like Prototype 2, GTA IV from the list below and need to see if it'll fix to my mother board
Also need to see if it's compatable with my system
- Geforce 8400gs 512mb 64bit
- ATI RADEON HD 5570 1GB DDR3 PCI-E
- ATI Radeon X1600Pro 512mb PCI-E
- Nvidia GeForce GT 430 1GB GDDR3
- Gigabyte Nvidia Geforce210
- Asus GEFORCE GT 610 DDR3 2GB
- Asus HD5450 1GB DDR3
Mother board images ( http://www.asrock.com/mb/overview.asp?cat=CPU&Model=G41... )
The following is a copy of my dxdiag. ( PC has a x64-based processor )
I can change my OS to win7 32bit,64bit or to win8 pro 32bit,64bit
System
Computer name: ********
OS: Windows 8 Pro 32-bit (6.2, Build 9200)
Language: English
System Manufacturer: To be filled by O.E.M
System Model: To be filled by O.E.M
BIOS: Default System BIOS
Processor: Intel(R)Core(TM)2Duo CPU E7400 @2.80GHz (2 CPUs), 2.8GHz
Memory: 4096MB RAM
Page file: 2222MB used, 1753MB available
DirectX Version: DirectX 11
Display
Device
Name: Intel(R) G41 Express Chipset (Microsoft Coporation - WDDM 1.1)
Manufacturer: Intel Coporation
Chip Type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Type: Full Display Device
Approx. Total Memory: 1534 MB
Current Display mode: 1024x768 (32bit) (60Hz)
Moniter: Generic Non-PnP Moniter
Drivers
Main Driver: igdumd32.dll,igd10umd32.dll
Version: 8.15.10.2702
Date: -
WHQL Logo'd: Yes
Feature Levels: 10.0,9.1
Driver Model: WDDM 1.1
DirectX Features
DirectDraw Acceleration: Enabled
Direct 3D Acceleration: Enabled
AGP Texture Acceleration: Enabled
Sound
Device
Name: Speakers (VIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_4397&SUBSYS_18...
Manufacturer ID: 1
Product ID: 100
Type: WDM
Default Devise: Yes
Drivers
Version: 6.00.0001.10500 (English)
Date: -
WHQL Logo'd: Yes
Other Files:
Provider: VIA Technologies, Inc.
PLEASE HELP
More about : chosing graphics card
a c 178 U Graphics card
February 2, 2013 6:18:41 AM
Please tell your buget and max resolution.
February 2, 2013 6:52:39 AM
1280x960
100 usd
Best solution
February 2, 2013 7:17:36 AM
Get this - http://www.newegg.com/Product/Product.aspx?Item=N82E168... Hd 7750 is best choice.you will able to play every game at high settings.
February 2, 2013 7:49:16 AM
Best answer selected by Sanyh.
February 2, 2013 7:56:15 AM
It uses 43w at peak.you should have 400w psu.
