Does this power supply have the correct cables?
3 answers Last reply
More about does power supply correct cables
  1. yes it has 4 4pin connectors you only need 2
  2. Yes, the Corsair has two PCI-Express 6+2-Pin connectors and your XFX HD7950 Double Dissipation AMD/ATI Graphics Card - 3GB only requires a single 6 pin PCI-E power and a single 8 pin (6+2) PCI-E power connector.
    The four 4 pin connectors omaroma refers to are the molex connectors used for powering fans, DVD drives, etc... They can also be used for the HD7950 but this power supply already has connectors (6+2) specifically for this purpose.
    thanks mate, installed this psu this morning, SO QUIET!
PowerColor Power Supplies Cable PCI Express Graphics
