Hello, I have an evga gtx 670 ftw video card. My pc's 6 pin pci-e dongles are L shaped making one impossible to connect to the video card. Is there any remedy to this? Thanks.
If you mean that the pci-e 6pin connectors from your power supply are angled then you could get some pcie extension cables which end with a normal 6pin connector. Or you could use a molex to 6pin adapter, but I wouldn't.
