Oxygen problem: phone is not found
  • Nokia
  • Phones
  • Cable
Last response: in Brands
Anonymous
August 22, 2005 4:14:41 AM
Archived from groups: alt.cellular.nokia (More info?)
Hi,
I have a nokia 5510.
I have a USB data cable.
I installed the cable, it's been registered on COM port 3 (as a USB
prolific driver).
When I start Oxygen, it says the phone is not found.
I tried with the phone on and off, but the result is the same.
Is there any solution?
Thanks
Dario
More about : oxygen problem phone found
Anonymous
August 22, 2005 7:54:11 AM
I looked at the item. but it seems to be the AUDIO TRANSFER cable, that
I already own.
The question now isa: Can I use this cable with Oxygen?
Correct me if I'm wrong, and thanks for any hints.
Dario
Anonymous
August 22, 2005 8:16:52 AM
I confirm that I own the Nokia. DKE-2 cable.
I downloaded Oxygen BUT in the connection wizard the DKE-2 cable is not
mentioned.
Can you head me on the right way? Do I have to use another software?
Thanks!!
Dario
August 22, 2005 2:18:47 PM
"ProgDario" <dario@fga-software.com> wrote in message
news:1124694881.215687.25320@g44g2000cwa.googlegroups.com...
> Hi,
> prolific driver).
> Thanks
> Dario
Yes, but you may not like the sound of it. I have spent many hours
installing and investigating 'so-called' Nokia datacables. The bottom line
is that they are unreliable at best. You will save yourseld hours if not
days of grief by getting the real deal.
The cable you need is a Nokia DKE-2. It will install without a problem.
Check on eBay for item number 5799271141 Currently the guy has some for
sale @ £4.99
Don
