Does ddr3 graphic card works on my system
February 3, 2013 1:08:07 PM
Hello,
friends any one help me my mother has one purple colour slot and two yellow slot.and it indicates pciex1 whether it is pcie x16 are agp graphic card slot .......and suggest me i could be able to use pci exprees 2.0 x16 graphics card [ddr3] or not.
my system requirement is
2 gd of ram
mercury motherboard[p1945gcm]
400w power supply
a b U Graphics card
February 3, 2013 1:26:36 PM
I looked up the specifications for that motherboard, and I don't see any purple slots - there are blue slots for the memory, yellow slots for non-express pci expansion cards, and a red/orange slot for pci express x16.
a b U Graphics card
February 3, 2013 1:30:35 PM
p1945gcm specs
You have 1 PCI Express x 16 slot, you can run any pcie graphics card. Memory type [dd3-ddr5] does not matter. You should now check the psu, that would be another factor in your ability to upgrade, does it have the 6 or 8 pin you need.
