Tom's Hardware > Forum > Audio > Audio Technology > Problems with NAD 3130
Forum Audio : Audio Technology - Problems with NAD 3130
Archived from groups: rec.audio.tech (More info?)
Hello, i have these settings:
Left 8 ohm, Right 8 ohm }Speakers
Left 4 ohm, Right 4 ohm }Speakers
NAD 3130
XBOX
When i have the volume at low sound it doesent come any sound to the
two right speakers.
Ofcourse i wonder why, and what can i do about it?
Greetings, Adam
Sponsored Links
This may be from a cold solder connection especially in the output stage. If
your model uses a protection relay, the contacts may be going bad, or may be
oxidized.
Take care that the specs for your amp are rated for 4 ohms. Many of these
amps are 8 ohm only, and the output stage will overheat when using 4 ohm
speakers. Overheating the output stage, can lead to some very expensive
problems to deal with.
Jerry G.
"Alj" <sjogras@hotmail.com> wrote in message
news:c461bfac.0408071022.548b896d@posting.google.com...
NAD 3130
XBOX
two right speakers.
Greetings, Adam
Reply to Anonymous
"Jerry G." <jerryg50@hotmail.com> wrote in message news:<cf44tb$j0d$1@news.eusc.inter.net>...
> oxidized.
> Jerry G.
> NAD 3130
> XBOX
> two right speakers.
> Greetings, Adam
Okey, i will check that about oxidation, but are you sure that i may
ruin my amp if i use those settings?
The Amp has a switch that lets you choose betwen 8ohm and 4ohm, what
should i then use, i have as i said 2 8ohm speakers and 2 4ohm
speakers.
Reply to ALJ
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
