Problems with atikmpag.sys
Hello,
I have 2x6950 in crossfire, when I try and update with new ATI drivers I get a blue-screen. Any help would be great. This also happens in game.
On Tue 05/02/2013 01:15:50 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020513-11824-01.dmp
This was probably caused by the following module: atikmpag.sys (atikmpag+0x8DB8)
Bugcheck code: 0x116 (0xFFFFFA800A6981C0, 0xFFFFF88004078DB8, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\atikmpag.sys
product: AMD driver
company: Advanced Micro Devices, Inc.
description: AMD multi-vendor Miniport Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmpag.sys (AMD multi-vendor Miniport Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
1 answer Last reply
More about problems atikmpag
  1. I've been testing my 2 old HD6850s in CF on my friends PC and after installing the second card Windows wouldn't boot further than the welcome screen, it'd just restart.
    To fix that I went into safe mode, opened up the registry editor and went to [HKEY_LOCAL_MACHINE\\SYSTEM\\ControlSet001\\Control \\Cl ass\\{4D36E968-E325-11CE-BFC1-08002BE10318}] and then searched for EnableULPS and changed the value of every instance of EnableULPS to 0.
    It disables ULPS which is known for causing all kinds of problems on duall-GPU systems.
    Try that :)
Graphics Cards Graphics
