Tom's Hardware > Forum > Audio > Audio Technology > Aiwa Cassette Deck Belt Repair?
Forum Audio : Audio Technology - Aiwa Cassette Deck Belt Repair?
Archived from groups: rec.audio.tech (More info?)
Does anyone know how the drive belts are arranged
on an Aiwa AD-F800 cassette deck?
There are two belts, and seemingly
three things for them to wrap around:
--a large flywheel that drives the take-up spindle
(and also engages the mechanism that lifts the
heads and pinch rollers into place for playback),
--a smaller flywheel that drives the feed spindle,
--and the drive shaft of a small motor at the top rear
of the transport assembly.
Both belts have slipped off, and
I can't figure out how they go back.
Thanks in advance.
--David Perris
Sponsored Links
David,
First let me tell you that I don't remember this model, so my reply is
not specific to your machine.
If the belt have slipped off, then they are also likely to have
stretched out in size and need replacement. The large, flat belt is
likely to go around the cast metal flywheel to the capstan, and the wide
section of the motor pulley. The smaller square belt from the small
section of the motor pulley to the reel drive.
Again, belts almost NEVER fall off unless they are too large, or
someone has forced something in a jammed mechanism. For good belts to
fall off even in transit, the machine would be damaged beyond repair.
Regards,
Tim Schwartz
Bristol Electronics
> Thanks in advance.
> --David Perris
Reply to Anonymous
Tim:
Thanks so much for the reply.
The machine was sitting unused for a long time,
so I suspect the belts degraded.
Actually, the two belts are both flat ones,
and the two flywheels are attached to the take-up
and feed spindles, rather than to the capstan--
I think there's a separate motor for that. The big flywheel
has some kind of clutch mechanism that engages just long enough
to lift the heads into place when you press Play, then kicks itself back
into driving the takeup reel. It's kind of hard to figure out where the
belts go, and they fell off before I could make a sketch.
I'll take another look inside. Thanks again for your help.
--David
in article 411E0796.986AF33F@worldnet.att.net, Tim Schwartz at
toschwartz@worldnet.att.net wrote on 8/14/04 8:37 AM:
> David,
> Regards,
> Tim Schwartz
> Bristol Electronics
>> Thanks in advance.
>> --David Perris
Reply to Anonymous
Is it an auto-reverse deck? If it's single direction, with 2 flywheels, then
one flat belt goes from one flywheel to the motor pulley, the other flat
belt loops around the outer circumference of both flywheels.
If it's an auto-reverse model, then normally one belt loops from the pulley,
over the top of one flywheel, and under the second, coming back around the
top over to the motor pulley.
Mark Z.
Please reply only to Group. I regret this is necessary. Viruses and spam
have rendered my regular e-mail address useless.
"David Perris" <dperris@att.net> wrote in message
news:BD43B861.888D%dperris@att.net...
> Tim:
> --David
> > David,
> > Regards,
> > Tim Schwartz
> > Bristol Electronics
> >> Thanks in advance.
> >> --David Perris
Reply to Anonymous
There are 703 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
