Decent low power PCI Express x16 slot
can anyone reccomend a decent pci express video card for my system
my spec
intel pentium dual core e2140 1.6ghz
2gb ddr2 ram
360gb sata hard drive
model number compaq sr5315uk
300w power supply
i have been on the website for my pc and it says it has PCI Express x16 slot
its only for some old games like just cause ,modern warefare 2 and some others
the onboard video is awfull and wont play any games with decent fps
3 answers Last reply
More about decent power express slot
  1. 7750 for sure. I wouldn't trust your psu for anything else. 7750 doesn't require a pcie connector from the PSU.
  2. 7750 for sure. I wouldn't trust your psu for anything else. 7750 doesn't require a pcie connector from the PSU.
  3. +1 to 7750. It should give you decent performance on older games, I get 50+ FPS on BO2, FC3, Crysis 3 with my 7750 but I have a 6 core CPU too, so that might limit you a bit on newer games but older games should work fine.
Graphics Cards Power PCI Express Graphics
