Help! - Nvidia 560 ti Very hot even under minimal load
Is this normal?? I don't recall it being this hot under zero load before?
Specs:
Case
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Overclocked CPU
Overclocked Intel® Core™i5-2500k Quad Core (3.30GHz @ max 4.60GHz)
Motherboard
ASUS® P8Z68-V/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX
Memory (RAM)
4GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz X.M.P(2 x 2GB KIT)
Graphics Card
1GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
Memory - 1st Hard Disk
750GB WD CAVIAR BLACK WD7502AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader
INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply
CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£87)
Processor Cooling
TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
Thermal Paste
ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options
6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Here it is with factory clock:
1 answer Last reply
More about help nvidia minimal load
  1. I know this may sound stupid, but since this has happened to me before, you don't have any benchmarking programs running in the background, do you?
Graphics Cards Graphics
