Need urgent help
Hello toms hardware, i m facing another problem with my pc.
I started fifa 13 and approx playing 1 minute, my pc has fully stopped!
I dont know why that happened. Again i started my pc and want to play far cry 3 and again playing 1 minute the pc stopped!
I again started and checked with 6 games same thing happens! :(
But if i simply start my pc and keep it simple and just browse internet then it doesnot happens!
But again i play hitman it again happens!
Any solution Members?
I need it.
More about : urgent
Related ressources
aniket1097 said:
My motherboard is overclocked. I have unlocked 4 cores of my motherboard. yes i have updated my gfx and has current version.
Revert it back to two cores and test. Making a dual core use all 4 cores that are on die can have issues as many times one of the two disabled cores is faulty. The faulty core may simply not generate errors until you stress the CPU.
