7950 graphics card help!
3 answers Last reply
More about 7950 graphics card help
  1. The Gigabyte is probably the best of those cards and the Sapphire is a close second. The other one is not bad at all, but it's considerably more expensive than the Gigabyte while being ever so slightly slower.
  2. The ASUS:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121716&Tpk=asus%20hd7950
    Asus website:
    http://www.asus.com/Graphics_Cards/HD7950DC23GD5V2/
    As long as you have enough space (3-slots) this is a great card. I have the 680 version and the large heatsink makes the card much less noisier.
    Pros:
    - quieter
    - probably better overclocking potential
    - backplate? (mine does, couldn't find a picture of the back)
    Cons:
    - 3-slots ( a non-issue if you don't need those slots)
    Other:
    Don't forget to verify that it fits in your case, and your PSU can handle it (min 550Watt PSU with enough 6-pin/8-pin connectors)
  3. You don't need a 550W PSU for a 7950. Many good 500-520W models are plenty for it. Overall wattage of a PSU matters far less than the +12V power delivery.
Graphics Cards Gaming Games Graphics Product
