Can I power a GTX 680 w/ a 6+2 pin and 6pin connectors?
  • Graphics Cards
  • Gtx
  • Power Supplies
  • Power
  • Graphics
  • Product
February 9, 2013 9:59:01 PM
Hi there. Today, I went out and bought a GTX 680 (THis one: http://www.newegg.com/Product/Product.aspx?Item=N82E168...). My power supply is able to supply the power needed; it's 750W.
However, I'm stuck with just a 6+2pin and an 6pin PCI connectors. If I plug these two in the two 8pin ports on the graphics card, will things work? Will something get damaged?
Thanks.
More about : power gtx 680 pin 6pin connectors
a c 342 U Graphics card
a c 166 ) Power supply
February 10, 2013 2:01:16 AM
What is the make and model of your power supply? It doesn't sound like it is a 'true' 750W if it only has 1 x 6+2 and 1 x 6 pin PCIe cables. The short answer, however, is yes... it should work because the +12V header on the card is being fed. But if your PSU is a cheapie, you'll have problems.
m
l
February 10, 2013 3:14:52 AM
It's an Antec "Earthwatts" 750watt power supply.
m
l
a b U Graphics card
February 10, 2013 3:22:50 AM
You should be fine. Power supply come with 8 pin connectors that are split into 6+2 to suit differenc power need by difference GPU classes. So yes you should be ok.
m
l
February 10, 2013 3:28:32 AM
I only have one 6x2 connector though. The other is just 6, and the card needs two 8's. Is it still ok to just use the 6x2 and the normal 6 then?
m
l
February 10, 2013 3:32:44 AM
The site you linked us to says it has 2 x 6-Pin, 2 x 6+2-Pin
m
l
February 10, 2013 4:03:04 AM
I checked the supply, it is that model, but the connecters it lists aren't there. I've looked though everything.
m
l
February 10, 2013 6:00:29 PM
Then they owe you a replacement. Can you still RMA it?
It should have a pair of PCIe power cables hard-wired, and another pair on a common modular cable. You should have 5 modular cables and the power cord.
m
l
