HELP!!!AMD Vision/Catalyst Control Center Problems
Hello
I have made a major f$ck up. I was messing around with the overclocking in the AMD Vision/Catalyst Control Center and now when ever I open the program the fans on my vid cards max out and then a few seconds later my entire pc crashes.
I have tried uninstalling and re installing AMD Vision/Catalyst Control Center but it still happens.
Any suggestions on how I can switch back to the default settings?
3 answers Last reply
More about help vision catalyst control center problems
  1. did you try the cmos reset ?
  2. I am trying to avoid doing that. I uninstalled the software and it seems ok but I need that software
  3. install it back but be carefull when you will overclock again the settings where to high .
Radeon Overclocking Catalyst AMD Graphics
