Gainward 660ti phantom bus interface issue
ighamerz
90
these are my system specs
cpu: I5 2500k 3.3ghz
cpu cooler: antec 620
mobo: asrack z77 extreme 4
ram: vengeance 4x2g
graphics card: gtx 660ti 2gb phantom II
Hdd: WD 500g
psu: corsair vx550
case: nzxt phantom
My question is, why my bus interface in gpu-z is only showing PCI-E 2.0x16, that the card must be pcie 3.0?i try running different version of gpu-z
but still the same issue showing, i also try different driver version but nothing new happens
but when i try to intall my older card xfx7850 core edition, it shows normal bus interface which is 3.0x16? is this normal or card powersaving features?
pls. help
Anik8
761
I use the same mobo,it has two pcie slots but the one at the lower end is 2.0 and the one closer to the cpu socket is 3.0 so make sure you have installed the card on the upper slot.
