Help! Problem w/4508
Forum Home Cinema Equipment : Ptv Replaytv - Help! Problem w/4508
Archived from groups: alt.video.ptv.replaytv (More info?)
I'm having a problem with an unmodified 4508 model. The power light started
blinking (the unit started re-booting on its own) and I can't get it to stop
(or finish booting). I tried unplugging & soft booting. I really need to
save the shows on the hard drive. Any suggestions?
Thanks
Sponsored Links
I very strongly suspect the hard drive MIGHT be the problem.
That said, some older Replays had a hardware component which serves no
useful purpose, but does cause problems SIMULAR (I'm not sure if it's
exactly) like yours... I also don't know which models it is, I know my
5xxx units do not have this module.
Others will be able to tell you more
> Thanks
John F Davis, in Delightful Detroit. WA8YXM(at)arrl(dot)net
"Nothing adds excitement like something that is none of your business"
Diabetic? http://community.compuserve.com/diabetes
Reply to Anonymous
- 0 +
John in Detroit <Blanked@sbcglobal.net> wrote in
news:RE5Pe.1406$eQ.588@newssvr30.news.prodigy.com:
>> started blinking (the unit started re-booting on its own) and I can't
>> get it to stop (or finish booting). I tried unplugging & soft
>> booting. I really need to save the shows on the hard drive. Any
>> suggestions? Thanks
Well if you REALLY need the shows, you can remove the hard drive and
plug it into your PC (either internal or via a USB case) then use the
rtvextract utility.
Or, pull the drive as above and use the disk image utility rtvpatch to
clone your old disk to a new one (maybe even increase the size). you can
optionally have it move your existing shows (it will take awhile though.
Another option, it to try and get it to boot and stay up, then use DVA
to pull the shows across the ethernet.
When my 45xx unit was endlessly rebooting I was able to stabilize it by
hitting the bypass switch when it booted. Turned out a bad spot on the
drive and when the live buffer tried to write to it the unit would die.
maalox, can you describe in more detail the RTV boot process?
Do you get the please wait screen?
Are you connected via RF or RCA cabling? Does anything comeout of the
TV? Most importantly, does it begin to buffer, flash and freeze and
then reboot?
Reply to Steph
Hey Steph & John & all replayers,
Sorry about the delay in response from the previous post.
Anyway, the touble w/my non-modified 4508 started one afternoon when the
unit was in the off mode (ac was plugged in obviously but I didn't have it
connected to a phone line or networked at that moment). It shows the Please
Wait screen. The unit doesn't soft boot & when I unplug it to hard boot,
still the same Please Wait screen.
I also have audio/video sync problems w/this unit. If I record anything over
an hour in duration, the audio is slightly behind the video after the first
hour of playback.
Now, I can easily change drives but I really need a couple of shows off the
existing drive. I've never used rtv extract.
What worried me most is the audio/video sync problem. I don't know if that
is a hard drive issue or if it's a motherboard issue. If the audio/video
sync problem is not correctable w/a new hard drive, I'd rather just send the
unit back to replay for a 5500 series. I have a couple of 5000 series units
so I'll still be able to network w/others.
Any/all suggestions are appreciated.
Thanks!
"Steph" <CUT_skipatrol@hotmail.com_CUT> wrote in message
news:Xns96BD96875B5EFskipatroluunet@66.75.43.157...
>>> suggestions? Thanks
> rtvextract utility.
> then reboot?
Reply to Anonymous
On Sun, 28 Aug 2005 19:02:45 GMT, "maalox" <maalox1@hotmail.com>
>hour of playback.
>Thanks!
Changing the drive should fix it, but may now.
I have one Replay that has the A/V sync problem on some recordings,
regardless of the drive used.
BTW, at least I have had that unit long enough for it to have been
worthwhile to have lifetime activation.
>>>> suggestions? Thanks
>> rtvextract utility.
>> then reboot?
Mark Lloyd
has a Replay 5xxx
http://notstupid.laughingsquid.com
"The idea that there is an invisible being who
created and still runs this old universe is so
childish, so obviously contrived, that it is hard to
believe anyone with even a modicum of education can
still fall for that scam."
Reply to Anonymous
On Sun, 28 Aug 2005 16:48:47 -0500, Mark Lloyd
>>hour of playback.
>>Thanks!
Possible spelling checker F-up above: "now" was supposed to be "not".
>>>>> suggestions? Thanks
>>> rtvextract utility.
>>> then reboot?
Reply to Anonymous
Tom's Hardware > Forum > Home Cinema Equipment > Ptv Replaytv > Help! Problem w/4508
There are 487 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
