Tom's Hardware > Forum > Mobility Brands > Nokia Ringtones > 3200 ringtone problem
Forum Mobility Brands : Nokia Ringtones - 3200 ringtone problem
Archived from groups: alt.cellular.nokia.ringtones (More info?)
Hi !
I passed a midi ringtone
using PC suite.
In my telephone the file arrive regularly
but I am not able to open it.
I passed the same ringtone in a 6230
without problems.
Can you help me, please ?
Thanks
Sponsored Links
"waiting" <waiting@aol.com> wrote in message
news:2odpjgF993lkU1@uni-berlin.de...
> Hi !
> using PC suite.
> without problems.
> Thanks
Did you select your mobile phone model as the 6230 or 3200 when you
configured the ringtone in PC Suite? Different Nokia phones have different
instrument capabilities, so what works on one might not necessarily work on
another model. I'd recommend you try to reconfigure the midi file using PC
Suite (if your version doesn't have the 3200 as an available option then try
downloading the latest version of PC Suite from the Nokia website) and
specifically select the 3200 as your handset.
HTH
Chris Michael
www.INTOmobiles.com
Download 100s of ringtones, wallpapers & logos every month for only £1.50
per week
Reply to Anonymous
Thaks.
I do use PC Suite
amd select 3200.
That is why I don't understand.
"Chris Michael" <news@intomobiles.com> ha scritto nel messaggio
news:2odu2vF9jl0cU1@uni-berlin.de...
> > Hi !
> > using PC suite.
> > without problems.
> > Thanks
on
try
> HTH
> Chris Michael
> www.INTOmobiles.com
> per week
Reply to Anonymous
There are 840 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
