[HELP] No Signal from Monitor
February 16, 2013 2:36:35 AM
Hey everyone,
I recently bought a PC from IBUYPOWER and received it today. I turn it on and I get no signal from my monitor. Here are some steps I have taken:
1) Ensured that everything is plugged in correctly
2) Taken out the GPU and re-inserting it
3) Tested the monitor with my old PC and it worked fine
Neither step 1 nor 2 helped. I also noticed that the GPU's fan is not running when the pc is on. I think there may be an issue with the connectivity between the GPU and motherboard?
my specs are as follows:
1 x Case NZXT Phantom 410 Gaming Case - White
1 x Processor Intel® Core™ i5-3570K Processor (4x 3.40GHz/6MB L3 Cache) - Intel Core i5-3570K
1 x Processor Cooling Liquid CPU Cooling System [SOCKET-1155] - ARC Silent High Performance Fan Upgrade
1 x Memory 8 GB [4 GB X2] DDR3-1600 Memory Module - G.Skill Ripjaws X
1 x Video Card AMD Radeon HD 7870 - 2GB - Single Card
1 x Video Card Brand Major Brand Powered by AMD or NVIDIA
1 x Motherboard ASUS P8Z77-V LX
1 x Power Supply 650 Watt -- NZXT HALE82N-SI / 80+ Bronze
1 x Primary Hard Drive 1 TB HARD DRIVE -- 32M Cache, 7200 RPM, 6.0Gb/s - Single Drive
I would really appreciate it if anyone can offer me some help.
More about : signal monitor
