Upgrade Graphics Card Help
Hi,
I am looking to upgrade my graphics card, I am a bit of a newbie when it comes to finding what will work with my motherboard etc, so any help would be grateful. I'm looking at a new graphics card between £50-£100 - Cheaper the better in all honesty.
I'm currently running Intel Quad Core Q6600 @2.40ghz, 2GB RAM, NVIDIA GeForce 8600 GT and NVIDIA NFORCE 680i SLi motherboard.
1 answer Last reply
More about upgrade graphics card help
  1. Roger_346 said:
    Hi,
    I'm pretty sure that board (all NForce 600 series) are PCi-E 1.0. That means the new AMD 7000 series with PCI-E 3.0 won't work on them, see:
    http://www.overclock.net/a/the-final-answer-to-the-controversial-pcie-x16-version-compatibility
    Specifically:
    We all know that the AMD Radeon HD 7000 series is extremely power efficient. Having said that it comes at a cost. This power efficiency comes due to the new electrical interface featured in PCIe v3.0 and 2.0 slots and is ABSENT in PCIe v1.1 slots. Hence they are NOT COMPATIBLE."
    So before you go spending any money, you'll want either Nvidia, or last generation AMD. That may help you to narrow down your choice.
    I would recommend something along the lines of a GTX 650, or GTX 650 Ti.
Graphics Cards Motherboards Graphics
