New GPU doesn't let the system POST
thanasulas
Hello everyone,
I really need your help here. I bought a new GPU and as you can see in the thread's name, now I can't POST into BIOS.
The GPU works fine on a different computer.
My motherboard:
http://www.asrock.com/mb/VIA/4CoreDual-VSTA/
My new GPU:
http://www.msi.com/product/vga/R7750-PMD1GD5-OC.html
I have read many posts in these forums but none is like my case.
1) My PSU is 600 watts so that not the problem.
2) MY computer doesn't post so drivers is not the problem(tried reseting).
3) Putting my old GPU in works fine.
4) The computer posts without the new GPU but doesn't boot windows because there is no on-board GPU.
5) I don't think I have done something wrong with the cables.
6) WTF?
Thank you in advance!
P.S. If you need more information, I will gladly tell you anything you need to know.
Maxx_Power
It is MOST LIKELY because the PCI-E specification on that board is too old. AMD PCI-E 3.0 cards are backwards compatible ONLY TO PCI-E 2.0, NOT EARLIER.
Your board is from an era where there was still AGP, in fact, your board has both AGP and PCi-E (which is rare, rare, rare). This means your board has a PCI-E revision stuck in the 1.0-1.1 range (as per VIA and PCI-SIG pages, see http://www.pcisig.com/developers/compliance_program/integrators_list/pcie/).
See this full featured post on the state of affairs on PCI-E backwards compatibility, and why:
http://www.overclock.net/a/the-final-answer-to-the-controversial-pcie-x16-version-compatibility
Particularly this quote:
"(AMD 7000 series)...new electrical interface featured in PCIe v3.0 and 2.0 slots and is ABSENT in PCIe v1.1 slots. Hence they are NOT COMPATIBLE."
Maxx_Power
Cheers! You might as well upgrade if you have a Core 2 only, if you can sort out some money for it, that is. I would strongly recommend this path.
thanasulas
Yes I will because even if I didn't want to change the cpu the socket is really stone age so new motherboards won't support it.
Whats your suggestion for motherboard + cpu around 100 Euros?
Maxx_Power
Well, I'm not familiar with the Euro pricing scheme. For only 100 Euros, I would say you will have better luck with AMD and the FX (piledriver) based CPUs. Perhaps a FX4300 or FX6300, and an AMD 970 chipset motherboard. Is the Gigabyte GA-970A-D3, Rev. 3 (NOT the DS3) available for cheap ? It is a decent board for single GPU configs.
