Wireless network using usb mobile broadband dongle
Hello,
I have a mobile broadband connection using a usb stick ( t mobile) Is there any way I can create a wireless network using this connection so I can share it with another device, ie a galaxy tab 7.7
6 answers Last reply
More about wireless network mobile broadband dongle
  1. Thanks for the reply
    If I get a 3g/4g router what is my next step?
  2. these routers work like your regular routers except you can connect a USB modem to it.
    once you connect the USB modem, setup the wireless network and connect your laptop or tablet
    Yep, got the 3g router
    Works a treat
    Many thanks :)
  4. What router did you get? I am wanting to do the same thing but know nothing about them or the different brands that make them.
    tp-link mr-3220
    pretty sure any 3g/4g router will do it
Configuration Mobile Broadband Wireless Network Connection Wireless Networking Product
