Closed Solved
Can this power supply handle the sapphire 6670 gddr5 ?
I am considering buying this case: Thermaltake V3 Black Edition, and it comes with a 450w power supply.
My question: can this 450w power supply handle the sapphire 6670 gddr5 ?
Here's the link of the case from thermaltake's website:
http://www.thermaltakeusa.com/ttWWW/Product.aspx?S=1343&ID=1927
You can see the power supply model is: TR2 RX 450W
Here is the power supply link from thermaltake:
http://www.thermaltake.com/products-model_Specification.aspx?id=C_00001558
my current system specs:
Motherboard: Asus M4A88t-M USB3
CPU: AMD Phenom II x2 560 black edition (with cpu cooler hyper tx3 evo)
VGA: Integrated ATI HD 4250
Ram: 4GB @1333 Mhz
HDD: 1 Western Digital 750GB
DVDRW: 1 Sony
Case: cooler master elite 310 with a 400w standard power supply
4 answers Last reply Best Answer
More about power supply handle sapphire 6670 gddr5
  1. Best answer
    You shoudn't have any problems since the 6670 is a low power card, and newegg.com states that it need a minimum of a 400 watt PSU. I know people who used that card with a 300 watt PSU and didn't have problems.
  2. You will be more than fine :) Don't worry
  3. I know the price is good but I would not use that psu in any of my builds. It's obviously an old design with poor efficiency. Stick with a quality power supply. PSUs have been discussed many many time at Tom's.
    -Bruce
  4. Best answer selected by moby90.
Graphics Cards Power Supplies Cases Thermaltake Graphics
