Zotac nvidia 650 ti 1gb gddr5 auxiliary power supply
sekharz
36
Hello,
Does zotac nvidia 650 ti 1gb gddr5 needs an auxiliary power supply since my zebronics psu does not contain a 6 pin power cable...??
And i have a psu- ZEB-450W (DSATA), 20+4 PIN(Zebronics)...does it have a 6 pin connector..?
Do i hav to buy a new PSU??
which 1 will b the best..for a 450w supply..?
No no your psu will kaboom and your rs 11000 gpu will damage.do not ever run gpu which needs 6pin connector with local psu.i suggest get corsair cx 430w psu at rs 2500 at local store.
Well full system specs would help as well as an image or the info off the label(I want to know the power distribution of that unit). I have never heard of that power supply maker, so I will await this info.
They make 4 pin (LP4 molex) to PCI-E 6 pin adapters, but the power supply has to still have enough power.
sekharz
36
Is a 430 watt psu enough for the 650 ti..? :??:
I was thinking about a 500 watt coolermaster thunder series...??? :)
