Here's my system (theoretical) I plan on getting:
2.4 GHZ Pentium 4 Northwood B 533 MHZ FSB
1024 MB PC1066 RAMBUS
80GB WD 7200 RPM
24x12x40 Plextor CD-RW
GeForce-4 Ti-4600 128MB
10/100 3COM Ethernet Nic
16x DVDROM Drive
SB Audigy Gamer
Klipsch 4.1 Promedia (dunno if this matters)
Conextant 56k modem
Obviously, the 533MHZ FSB 2.4 GHZ and 1066 RAMBUS won't be available until late May (estimated).
The initial configuration for this system is 300 watts, but that doesn't sound enough.
Options are: 300W, 350W, 400W, 431W, 550W
What do you recommend for this system?
Thanks! ^_^
<font color=blue> There's no such thing as hell, but you can make it if you try.</font color=blue>
80GB WD 7200 RPM
16x DVDROM Drive
SB Audigy Gamer
Conextant 56k modem
Thanks! ^_^
