Graphic Card Problems
I just recently changed my XFX 6850 to a Twin Frozr II 560 GTX TI Factory Overclocked. When I'm playing games, my screen will freeze for a few seconds and green, purple, blue fuzz will appear on my screen. When I alt-tab it says that the Nvidia Windows Kernel Mode Drivers have crashed. I've tried reinstalling the drivers several times, updating them, and reseating my card. Not sure what to do, any help?
10 answers Last reply
More about graphic card problems
  1. Re-install windows :/ its the old drivers conflicting with the new ones. Use AMD's official uninstall application to remove the ati drivers completely
    Re-Install windows as a last resort. Look for a program called Driver Sweeper and use it to uninstall ALL GRAPHICS DRIVERS, then re-install the drivers for your current card.
    I actually just did that today, still having the same problems though.
  5. Hmm.. Is your power supply sufficient for your card?
    I believe so, it's a Coolmax 700w. I do have a Seasonsic 750x, but I haven't switched it out yet.
  7. Any 700w should have sufficient amperage for that card so thats probly not the issue. I guess just wait until someone more knowledgeable than me comes along and reples.
  8. Faulty card from what i make of it
  9. Did you roll back drivers? try different versions of the driver see if that helps
  10. I've tried several versions for the drivers, they all cause the same problem though.
Graphics Cards Drivers Graphics
