I am trying to decide which graphics card I should get, I would like to play upcoming games not necessarily on ultra but good quality.
Here are my parts I have slected so far:
Corsair Professional Series HX 750 Watt ATX/EPS Modular 80 PLUS Gold (HX750)
AS Rock LGA1155 DDR3 SATA3 USB3.0 Quad CrossFireX and Quad SLI A GbE ATX Motherboard Z77 EXTREME4
Cooler Master Hyper 212 Plus - CPU Cooler with 4 Direct Contact Heat Pipes (RR-B10-212P-G1)
Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
Intel Core i7-3770K Quad-Core Processor 3.5 GHz 8 MB Cache LGA 1155 - BX80637I73770K
Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ16GX3M2A1600C10)
I was looking at the GEFORCE gtx 680 but it is a bit pricey, I am new to pc building so all advice is welcome.
Do you think I should go with the i7? or i5?
Thanks!
Thanks!
