Xpertvision 4850 hd graphic card problem. Urgent Help Please.
  • Radeon
  • Computers
  • Graphics Cards
  • HD
  • Graphics
February 19, 2013 7:33:18 PM
Recently bought this graphic card for my friend as he needed a graphic card. Once i got the graphic card i noticed i needed a 8 pin connector which someone on this forum helped me find :)  i have got the connector and replaced my graphic card to test this one out. After putting the graphic card in my computer i turned it on and it doesn't seem to load up. At the start of the computer load up it comes up with saying something like this...
"Please connect power supply to hardware or something like that and also said follow a guide on how to install properly?"
Is there anywhere i can find this guide on how to install? Or is something wrong with the graphic card?
My own graphic card is a gtx 260 and that works fine. Any help would be appreciated!
More about : xpertvision 4850 graphic card problem urgent
February 19, 2013 11:01:44 PM
Here are the pictures of what the graphic card looks like.. i have plugged everything in.. Also this is what it says on startup.
The writing says "You have not connected the power cable to your video card, Please refer to the getting started guide for proper hardware installation"
Where is this guide?? or Any Help?
a b U Graphics card
February 19, 2013 11:07:36 PM
What's the name of your power supply unit?
February 19, 2013 11:12:51 PM
XFX pro550w core edition fully wired power supply
Also right click on the link and "view image" to see pictures. Not sure if it is showing.
a b U Graphics card
February 19, 2013 11:21:37 PM
What the hell dude? That power supply comes with its own 8 Pin power connection! the one you're using right now, whats it connected to? Looks like some kind of converter?
a b U Graphics card
February 19, 2013 11:22:19 PM
check the 6pin pci e connector on the psu it should have an extra 2 pins dangling next to it!
February 20, 2013 1:24:03 AM
The power supply has a totally different connection to this graphic card connection. The wires are stored away at the side and not connected to anything.
The connector i bought is connected to the power supply. It is the only connector that fits the gpu. I myself have a gtx 260 and needs 2 6 pin connectors and my gtx 260 works fine.
February 20, 2013 1:43:26 AM
I AM STUPID... THANKS MAN.. REALLY SORRY .. -.- do you know where i can find a connector that is the same as that 6 pin + 2? I need it for my friends computer. Also what driver should i be downloading... Thanks for all your help.. I am really sorry >.<
February 20, 2013 6:51:38 AM
Anyone know where i can get a 6+2 pin adapter molex? or a cheap power supply ? 450/550w ? that has the 6+2 pin. Thanks
a b U Graphics card
February 22, 2013 6:53:43 PM
The cheapest decent power supply with a 6+2 Pin going right now is the OCZ CoreXstream. It costs around 30-35 quid max Here lemme get you a link
http://www.dabs.com/products/ocz-technology-500w-corexs...
Or you could just spend 5 pounds more and get an XFX one. Check it out its on the same website.
