Need help on parts to get for my computer! please help!!
kevinc_48
34
Hello all, I am planning to upgrade my computer with a 200-300 dollar budget. Here is the issue, I cannot afford a new MOBO, GPU, CPU, and Ram all at the same time and will far exceed the 200 - 300 dollar budget (unless u can recommend me to cheap ones). But what do you suggest I do? Here are the specs for my current pc
Nvidia 9800 gt
4 GB ram
Pentium (R) Dual-Core CPU E5300 @ 2.60 GHz
Socket 775LGA
Bios: American Megatrend Inc. V2.5
Model: p43 Neo3 (MS-7514)
Do you guys think i should buy a new MOBO and CPU? The issue is that if i upgrade my MOBO and CPU... then my 9800 gt will bottleneck?? im not sure. Please help :( Can you guys recommend me a setup for my pc that will not bottleneck with my old 9800gt?
