Hello and thanks for the assistance ~_~
So I have an odd problem hopefully someone here can shed some light on it as I have no clue how to fix it at this point. I have a Westinghouse 32" monitor connected via HDMI cable to my m17x R3 laptop. Recently I bought an SSD and installed a new windows OS on it and formatted my old system. Upon installation when I connect my 32' my system reads the TV as 2 monitors instead of one.
The ONLY solution I've had recently was going into device manager and disabling NVidia then re-enabling it which caused the 3rd mystery monitor to disappear and performance to go back to normal.
What's more odd is that when I restart my system there are 1 of 3 random possible outcomes:
1) 20% of the time problem is fixed and there is no second monitor.
2) 20% of the time windows Aero is disabled and I have 3 monitors.
3) 60% of the time windows Aero is working and I have 3 monitors.
Recently I've tried multiple fixes based on just random theories:
1) Bought a new HDMI cable - didn't fix.
2) Marked SSD as active partition and completely removed first OS and everything in it - didn't fix.
3) Updated Intel and Nvidia drivers and tried other version - didn't fix.
4) Copied my old systems drivers to my new system as the old system never had this problem - didn't fix.
5) Updated BIOS - didn't fix.
Below are SS's of what I am seeing. The main problem I am having is that this problem is causing major performance issues with my system. My overall speeds have dropped to 1/5th of what they were previously during gaming sessions and the screen has been flickering etc.
Device Manager: (3 Generic PnP Monitors)
http://imageshack.us/photo/my-images/40/er3ab.jpg/
Windows Screen Resolution Panel: (3rd Ghost monitor)
http://imageshack.us/photo/my-images/255/er2k.jpg/
Nvidia Control Panel: (3rd Ghost monitor)
http://imageshack.us/photo/my-images/10/er1f.jpg/
To anyone that can help or has an idea on possible fixes I'd gladly appreciate it. The HDMI cable I bought is 25' so I am going to test it out on my 40' TV to see if the problem replicates itself to perhaps gain a better understanding of why I am getting the ghost monitor.
