Archived from groups: alt.video.ptv.tivo (More info?)
I'm having a codec-related problem with Tivo To Go. Here's the situation.
I installed the InterVideo DVD X-Pack, and sure enough, I could load shows
from the TIVO onto the laptop and watch them using Windows Media Player.
The problem is that the 'speed related' control is pause. I can't use the
fast forward or reverse buttons, and I can't even drag the slider to a new
location. In other words, if I want to see a point 1/2 hour into the show,
the only way to do it is to press play and then wait 1/2 hour!
I have heard that this is a codec-related problem, so I downloaded
"DScaler5005.exe". This fixes the problem with navigation, but messes up
the aspect ratio of the film.
Any suggestions as to how I can get both the correct aspect ratio and
navigation?
Thanks.
Sponsored Links
What version of Windows Media Player are you using?
Google around for "Windows Media Player" and "incorrect aspect ratio". I
can't recall off hand if it's too new of a version that causes a problem
or too old, but it's one or the other.
You can try a different player, like Zoom Player, or Media Player Classic.
Lenroc
Reply to Anonymous
"Lenroc" <lenroc@NOSPAMFORYOU.hotmail.com> wrote in message
news:ETtUd.10701$Sn6.9696@lakeread03...
Using version 10.
Reply to Name
> the fast forward or reverse buttons, and I can't even drag the slider to a
> new location. In other words, if I want to see a point 1/2 hour into the
> show, the only way to do it is to press play and then wait 1/2 hour!
> navigation?
One other issue: Even if I could get the aspect ratio right on the DScaler
codec, I can't really use it, since it causes DVD playing to fail!
In short, I need a codec that will get both navigation and aspect ratio, and
I don't know one that will do both!
Thanks again.
Reply to Name
This one works for me:
http://www.free-codecs.com/downloa [...] l_in_1.htm
The AR is somewhere between 1:1 and 4:3 and the navigation works fine.
"Name" <email@address.com> wrote in message
news:MYtUd.3891$2s.3549@lakeread06...
>> situation. I installed the InterVideo DVD X-Pack, and sure enough, I
>> could load shows from the TIVO onto the laptop and watch them using
>> a new location. In other words, if I want to see a point 1/2 hour into
>> the show, the only way to do it is to press play and then wait 1/2 hour!
>> navigation?
> DScaler codec, I can't really use it, since it causes DVD playing to fail!
> and I don't know one that will do both!
> Thanks again.
Reply to Anonymous
"BSackamano" <bsackamano@hotmail.com> wrote in message
news:QfuUd.70868$tl3.28068@attbi_s02...
>>> up the aspect ratio of the film.
>>> navigation?
>> fail!
>> Thanks again.
It turns out that resetting the video hardware acceleration to defaults
fixes the navigation problem in WMP. Go figure!
Reply to Name
Tom's Hardware > Forum > Home Cinema Equipment > Ptv Tivo > TTG CODEC problem
There are 1163 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
