I want to sort out some information here, so bear with me. Let me get some things in order first.
1-PC-800 runs at 400Mhz double pumped, meaning that it has a 100Mhz clock pushed four times
2-RDRAM has higher latency than SDRAM/DDR due to its need to be used in a serial mode (you would have to add the latency of 2 sticks of RDRAM to get the actual latency, right?)
2.5-Does RDRAM have lower latency (per stick) than DDR or SDR?
3-Because it is serial, EVERY port has to be filled identically, meaning that in no possible way, you could interlace different size modules (ie 128 and 256)
4-the PIV only tops out its current bandwidth with 3.2Gbs of RDRAM (1.6 X 2 sticks)
5-What is the highest bandwidth the Athlon can be fed by? (I'm guessing 2.1Gb/s?)
6-If someone can out with some magical DDR running at 400Mhz double pumped, it would run at 800Mhz synonymously like RDRAM, albeit with less latency, would this special brand of DDR be able to outperform the PIV with RDRAM?
I still have yet to see why Intel risked the PIV on Rambus, and is soon to withdraw from them. As I can gather, they plan on going northwood with 533FSB and PC-1066 RDRAM. If they do go with DDR later on, what can we expect for other memory types? Is DDR really the future?
"When there's a will, there's a way."
