Craphics card? please help
can anybody help me i bought a pc last year with a integrated graphics card a HD 6370D
im new to pc gaming. an wood like to put a graphics card in my computer
the pc is a hewlett packard
model p6-2200ea
processer amd e2-3200 apu with radeon(tm) hd graphics
ram 4 gig
is there anything i can do to get better graphics or do i need a better computer.thanks
12 answers Last reply
More about craphics card help
  1. A good video card is going to be bottlenecked by that CPU.
  2. is there any thing i can do to get better graphics? i rushed into buying it and never did any research. thanks for your fast reply
  3. I suggest to get hd 6670 1gb
  4. would it work with my pc?
  5. It will work.make sure you have pci exp 16 slot
    You can buy these:
    New CPU: http://pcpartpicker.com/part/amd-cpu-ad631xwngxbox
    New Ram: http://pcpartpicker.com/part/gskill-memory-f312800cl9d8gbsr (Assuming you have a 64 bit system)
    New Graphics Card: maybe something like a 6670
  7. my cpu is only 2.40 ghz does that make any difference?
  8. Not a much.might slow in some games
  9. thanks for reply yere really helping me alot,i have a have pci exp 16 slot ,would i need extra power for that card.mines 300 watts. will there be much differnce in graphics?.
  10. bump
    http://www.usedlaptopsireland.com/sapphire-radeon-hd-6670-1gb-ddr3pci-express-20800mhz1333mhz-33860-p.asp
    will this work? or do i need a better psu?
  12. It should work. But just to be on the safe side, upgrade your PSU as well.
Graphics Cards Computers HD Graphics Product
