Power Needs?
Forum Audio : Audio Technology - Power Needs?
Archived from groups: rec.audio.tech (More info?)
What would be considered a minimally adequate power (in watts) needed
to power a typical ( 6" to 8", reasonably priced) ) in-ceiling
speaker??
Sponsored Links
> speaker??
IT depends. You talking a 70 volt system, or one with an amplifier
built
into the speaker box? Where is this speaker going? In an office or a
factory? Your best place is to go to the manufacturer's spec sheet for
the
speaker. Consult a local installer who can come and do a site visit.
--Dale
Reply to Anonymous
"mathedman" wrote ...
> (in watts) needed to power a typical ( 6" to 8", reasonably
> priced) ) in-ceiling speaker??
Ambient sound levels (dentist office vs. boiler factory?)
Ceiling height?
Speaker spacing?
Speaker sensitivity/efficiency?
Program material (voice paging vs. high-quality music?)
Distribution method (70V constant-voltage?)
"reasonably priced" = ???
Reply to Anonymous
mathedman@hotmail.CUT.com (mathedman) wrote in message news:<416946da.73107122@netnews.worldnet.att.net>...
> speaker??
Here is an answer just as informative as the question: Try 100 Watts
and if that isn't enough try something bigger.
Otherwise either post enough information or, better yet, check with a
local contractor who can assist you. You really need to have an idea
as to how much the speaker can handle, what impedances are you dealing
with, and how much power you need for your application. As bad as it
sounds, it really isn't a matter of just rolling your sleeves and
getting the right amp without planning it out some.
Dennis
Reply to Anonymous
Tom's Hardware > Forum > Audio > Audio Technology > Power Needs?
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
