I recently purchased a new PC which is running a AMD XfX 9750 Video Card. The monitor I choose to use is a 60Herts 5MS 21.5 LED Flat Screen by Dell.
The issue that i'm currenty having is that I get small horizontal lines going up vertically in my monitor screen while gaming. These lines are not present durning load screens. Also the lines are relatively difficult to see if you to just glance at the screen. Lastly, I found with games line Diablo 3 that enable Vsynce that seemed to fix the problem.
My question for the community is this problem a result of my monitor or something else. Also I run any game pretty much on Ultra setting with 100 to 140 FPS. Lastly, if I were to replace my monitor which type should I aim for 2MS LED 120Herts?
Thanks for the help.
