Tom's Hardware > Forum > Audio > Audio Technology > high preout voltage usb sound card?
Forum Audio : Audio Technology - high preout voltage usb sound card?
Archived from groups: rec.audio.tech (More info?)
Anyone know of any soundcards with a high preout voltage? 4v and up. It
must have a USB interface. At least one analog input. The more analog
outputs the better.
Sponsored Links
"Mark Zarella" wrote ...
> 4v and up. It must have a USB interface. At least one analog
> input. The more analog outputs the better.
Seems pretty unlikely. 4v is higher even than professional
line levels. Why do you think you need such a thing?
Reply to Anonymous
Car application. I use a somewhat older subwoofer amplifier and it's tough
to get it to full output even with the gain setting all the way up.
Reply to Anonymous
"MZ" wrote ...
> tough
Shouldn't be that difficult to find a little line amp that runs on 12v.
Sounds like your subwoofer amp wants speaker level inputs.
You could find a pair of USB computer speakers and use the
amplifiers to drive your subwoofer amp.
Reply to Anonymous
On Fri, 15 Oct 2004 23:48:18 -0400, "MZ"
Is the amp expecting a feed tapped off a speaker output? Can't you
give it one? What's playing the mids and top of your car system?
Reply to Anonymous
tough
No. But 1v is too little to drive it adequately, especially on "quiet"
recordings.
> Can't you
Different amps. 1v may be too low for them as well. I don't know. Keep in
mind that the gain adjustments on car amplifiers tend to go down to 0.5v as
a minimum, with ~1v being more common. So to reach maximum output the
recording basically has to be close to 0dB. And with a lot of filtering
going on at the input (the amps are driving subs, woofers, mids, and
tweeters, all from independent channels), it drops the signal even more.
Reply to Anonymous
There are 1232 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
