Solved
Help purchasing new monitor
Hello all
I'm looking to purchase an IPS monitor 27-30" i have $700 to spend no more.
What do you guys think would be a good display to purchase? So far im looking at these 2 monitor:
Dell
http://www.newegg.com/Product/Product.aspx?Item=N82E16824260111
Asus
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236294
any help would be awesome and thanks in advance!
13 answers Last reply Best Answer
More about help purchasing monitor
  1. Between those 2 the Asus is by far superior. Better response time, sound and higher contrast ratio.
    http://www.lg.com/us/monitors/lg-IPS277L-BN-led-monitor
    I have the 23" version of the above linked one. It was excellently priced and I was not disapointed in the least. I live it. See if you can find it.
    Thanks you for the reply but im really looking for that resolution (2560 x 1440) as well.
  3. By all mean if there is a better manufacturer then those 2 i have linked please let me know. I dont think i want to import a monitor like the Yamakasi catleaps or the crossover monitors.
  4. Best answer
    Then that is a tall order and the prices you have are pretty good. Get the Asus... Much better :lol:
  5. I've got the 24" version of the Dell (U2412) and it works great. If there is any way you could get a look at these in person before you buy, do it.
    They're both good monitors, so you really can't go wrong.
  6. Just making sure i purchase the right monitor. $700 for me is quite a lot of money for a monitor. :D Thanks again for responses. What do you guys think about these monitors?
    http://www.overlordcomputer.com/overlord_tempest_X270OC_display_p/ot_x270oc_a.htm
  7. I have not heard of those ever... LOL can not help you much. Although the specs seem pretty decent.
  8. hahaha yea, I was in the hardware sub-reddit (reddit.com/r/hardware) seen someone talking about being able to oc the refresh rate on these monitors. They are very reasonable priced.
    I saw that. Pretty cool. As long as it does not effect warranty I would try those screens.
    To tell you the truth im not a "very leap of faith" type of person i think ill take your advice and order the Asus monitor. Thanks very much for all your help! :D
    Haha well at least you can be sure the Asus will serve you well... Enjoy!
  12. TYVM! Lets hope so.
  13. Best answer selected by chrono7.
Graphics Cards Monitors Graphics Product Displays
