Tom's Hardware > Forum > Audio > Audio Technology > Bose sound system
Bose sound system
Forum Audio : Audio Technology - Bose sound system
Archived from groups: rec.audio.tech (More info?)
Does anyone know a patent no. or other technical information
explaining how this sound system works? I mean the system
with the little cube speakers where you can't tell where the
sound is coming from.
Just curious,
Andy
Sponsored Links
"Andy" <spam@hotmail.com> wrote in message
news:2tioncF1vp2okU1@uni-berlin.de...
> Does anyone know a patent no. or other technical information explaining
> how this sound system works? I mean the system with the little cube
> speakers where you can't tell where the sound is coming from.
* The system Bose adopted was around for decades before Bose 'discovered'
it. (I very much doubt that a patent would be awarded to such a system which
is public domain)
* The Bose system is inferior to almost every other similar system.
* You can tell EXACTLY where the sound is coming from, with a Bose system.
The crossover points (particularly the bass module) are so poorly chosen
that this is a simple feat.
Trevor Wilson
www.rageaudio.com.au
Reply to Anonymous
In article <2tioncF1vp2okU1@uni-berlin.de>, Andy <spam@hotmail.com>
> Just curious,
> Andy
They probably mess with the phase of the left and right channels. Bose
uses extremely low grade building materials then compensates for some of
that using custom filters in the electronics.
There's old trick that was often called "Stereo Wide" on boomboxes of
the 80s. It's essentially crossed negative feedback between the two
channels with various filters varying the amount and phase by frequency.
Tuning it to sound good is tricky but once you've got that, it costs not
even $1 in electronic parts. At best is sounds good, at worst it causes
headaches.
Stereo Wide can be implemented in passive components too! The simplest
case looks like:
Amp Left ---------------------->
Speaker Left
Amp GND ----+--+---+---+ +--->
| R C L |
Amp GND ----+ +---+---+---+--->
Speaker Right
Amp Right ---------------------->
L passes through <200 Hz
C passes through >8 KHz
R controls mono pass-through
Reply to Anonymous
- 0 +
I suspected something like that. Also you can use some R-L
to eliminate the 'middle bits'. There should be a patent
detailing exactly what they did to optimize the effect, like
for instance US patent 5,105,462 does for QSound...
Andy
Reply to Andy
There are 1070 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
