Tom's Hardware > Forum > Audio > Audio Technology > To Dick Pierce - Power Input
Forum Audio : Audio Technology - To Dick Pierce - Power Input
Archived from groups: rec.audio.tech (More info?)
In 1972 Small (JAES) defined power input to a loudspeaker system as
that delivered to a resistor with the same value as the voice coil
resistance. IOW as the DC resistance of the coil. Do you know if
this has been standardized or adapted by the industry? TIA
ns
Sponsored Links
AES has adopted same AFAIK so that 1 watt in 8 ohms ( nominal impedance
speaker ) is now specified as 2.83V at the speaker terminals for
example.
Graham.
Reply to Anonymous
Pooh Bear <rabbitsfriendsandrelations@hotmail.com> wrote in
news:4177218D.252B55C3@hotmail.com:
> example.
> Graham.
2.83 volts is 1 watt into an 8 ohm load. For some strange reason most
speakers are 4 ohms but the manufacturers still use that same 2.83 volts
which translates to 2 watts, thus improving their speakers rated
sensitivity by 3 db.
r
Nothing beats the bandwidth of a station wagon filled with DLT tapes.
Reply to Anonymous
> > example.
> > Graham.
I've heard of this cheat. I don't think that reputable manufacturers use it.
Actually, most speakers are still 8 ohms IME.
Graham
Reply to Anonymous
news:417841E0.1EC44F37@hotmail.com:
impedance
>> > example.
>> > Graham.
volts
it.
> Graham
Graham,
It has been my experience that most new speakers are of the 4 ohm variety.
I could be wrong but I don't think so.
r
Reply to Anonymous
"Pooh Bear" <rabbitsfriendsandrelations@hotmail.com> wrote in message
news:417841E0.1EC44F37@hotmail.com...
it.
IME the reverse is true. The majority of HiFi speakers are now 4-6 ohms, and
the majority of manufacturers quote sensitivity for 2.83V, if they state a
figure at all.
Since the impedance curve of most speakers is far from flat, specifying an
input voltage is just admitting the reality of what was usually done anyway,
even if it was mislabelled as 1 watt.
TonyP.
Reply to Anonymous
>> reason most speakers are 4 ohms but the manufacturers still
>> use that same 2.83 volts which translates to 2 watts, thus
>> improving their speakers rated sensitivity by 3 db.
It is not totally unfair, most poweramps do in my understanding deliver
the same output voltage in 4 as in 8 Ohms under normal, non-clipped use.
It could equally well be described as mispresentation of the facts to
not use the same voltage for both impedances.
Fairness or cheat gets to be a matter of exactly what wording they use
and whether sensitivity is described as a voltage or a power
sensitivity. That said, if it is a voltage sensitivity that is specified
then it should be _obvius_ that so is the case and what the implications
are.
> Graham
Kind regards
Peter Larsen
* My site is at: http://www.muyiovatki.dk *
Reply to Anonymous
Seems to depend on the market sector.
Pro speakers tend to be 8 ohm as default, although 4 and even 16 ohm variants
may be offered too.
All the hi-fi speakers I've met have also been 8 ohm. Maybe the drive to low
cost pretty boxes has resulted in more use of lower impedance types ?
Graham
Reply to Anonymous
news:417F0AB8.278AB4C0@hotmail.com...
low
The biggest reason for the shift to 4 ohm IMO, is the wide spread use of 2
small bass/mid drivers per box instead of one larger one.
Mostly they wire two 8 ohm drivers in parallel, and get a nominal 4 ohm box.
The real impedance varies with frequency as always.
Very few manufacturers make 16 ohm drivers any more, so using two of those
in parallel is not a viable option to most box builders.
Also the fact that many amplifiers can deliver more power into 4 ohms than
8, is a benefit in most cases.
TonyP.
Reply to Anonymous
> the drive to low cost pretty boxes has resulted in more use
It appears that some manufacturers, example: Cambridge p500, prefer to
spec power in a somewhat lowish impedance - ie. 6 Ohms, no mentioning of
number of channels driven. The danish importer then quotes that loosely
worded power spec as the power spec for 8 Ohms ...
> Graham
Kind regards
Peter Larsen
Reply to Anonymous
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
