Source_for_Power_Caps.(2)_Needed:
Jim
2,444
Archived from groups: rec.audio.tech (More info?)
A week ago I emailed BHC Aerovox, Nichicon and several other
manufacturers, who advertise high quality power capacitors, but they
have not responded. Several others responded saying they don't carry
this cap. value. Where can I go to obtain high quality power caps.?
I need a pair of replacement power capacitors to replace the one's
originally manufactured by Nichicon and marked as follows
CE W
Nichicon 85°C
22,000 uf
80WV
60322
Application: One cap. is used on the power supply +60VDC rail and
another on the -60VDC rail.
Insulation color: black
Dia.=63.5 mm (desired to maintain this value for mtg. reasons)
Height approx. 120 mm (approx. max. ht.)
Spacing betwn screw terms = 28.6 mm
I'd like to upgrade to a higher voltage and temp. e.g. 105°C, if feasible.
Increasing cap. value is worth considering if the associated circuitry
can deal with the extended inrush current, etc.
What value of ESR (meas. freq.?) is desirable for these caps used in a
120W (8 ohm) audio power amplifier?
Thanks for your help and recommendations. Jim
G
Guest
Guest
Try here.....
http://www.chemi-con.com/files/U32DU32DH9.pdf
Looks like their 39,000uf at 100V 105c is the closest in physical size.....
same diameter slightly shorter than your measurement 2.5in x 4.625".....
the original was...63.5mm=2.5in 120mm=4.72in
If your distributor does not stock the U32 series you could try U36 85c
units...
The 33,000uf at 100V 85c is the closest 85c unit....
http://www.chemi-con.com/files/U36DU36DH9.pdf
Finding someone with units in stock might be more of a challenge...
Rgds:
Eric
"Jim" <jimhbr@Yahoo.com> wrote in message news:417769D4.8000504@Yahoo.com...
> CE W
> Nichicon 85°C
> 22,000 uf
> 80WV
> 60322
G
Guest
Guest
Newark Electronics (www.newark.com):
United Chemicon 36DA223F100CD2A
$33 each
you can also try Electronic Surplus in Cleveland, but the prior generation
of electrolytics is quite large compared to current production units.
"Eric K. Weber" <eric-nospam@webermusic.com> wrote in message
news:9qOdd.2$iC1.11157@news.uswest.net...
> Try here.....
size.....
> units...
> Rgds:
> Eric
> > CE W
> > Nichicon 85°C
> > 22,000 uf
> > 80WV
> > 60322
feasible.
G
Guest
Guest
Jim <jimhbr@Yahoo.com> wrote in news:417769D4.8000504@Yahoo.com:
> CE W
> Nichicon 85°C
> 22,000 uf
> 80WV
> 60322
http://www.percyaudio.com/catalog.pdf
See page 8. Nichicon KG series. They're not cheap.
--Damon
G
Guest
Guest
The KG series is snap lug not screw.... He needs the NR or NT series....
http://www.nichicon-us.com/english/seihin/alm_larg/param_f.htm
Part number LNR1K223MSM appears to be the proper p/n for the original
unit.....
http://www.mouser.com/index.cfm?&handler=data.listcategory&D=*LNR1K223MSM*&Ne=64700000&terms=LNR1K223MSM&Ntt=*LNR1K223MSM*&Dk=1&Ns=MfgrPartNumber%7c%7cSField&N=64700000&crc=true
A non stock item minimum order 4 at $29.22 delivery might be very slow as
Nichicon shows no US inventory....
As a result John's suggestion from Newark is your best bet....
Rgds:
Eric
"Damon Hill" <damon1six1@comcast.not> wrote in message
news:Xns95896810267D6damon161attbicom@216.196.97.134...
> > CE W
> > Nichicon 85°C
> > 22,000 uf
> > 80WV
> > 60322
> --Damon
G
Guest
Guest
> CE W
> Nichicon 85°C
> 22,000 uf
> 80WV
> 60322
Two 10,000uF in parallel per side, (4 total) will give the same performance.
These are more readily available.
80V rating should be adequate for a 60v supply. 105°C is good if you can
find them, or make sure the box is well ventilated.
Will provide no real benefit for a 120W amp.
Lower is better. Consider the ripple current rating as well.
TonyP.
G
Guest
Guest
I have a pair of Sprague Powerlytic 36D caps sitting here.
22,000 - 75VDC
If you are in or will be in NYC, you can pick them up for VERY few $$.
Kal
> CE W
>Nichicon 85°C
> 22,000 uf
> 80WV
> 60322
G
Guest
Guest
> CE W
> Nichicon 85°C
> 22,000 uf
> 80WV
> 60322
Why ?
What reason ?
If it's not running hot - you don't need 105C.
Bulk storage caps used at line frequency aren't often given a specific ESR
rating since it's rarely critical. This is more of an issue for SMPS caps @
100kHz. You might be more interested in ripple current but unless it's a
heavily driven PA amp, just about any modern electrolytic will be just fine.
22000 uF will havea high ripple current rating anyway.
You'll find that although 80V caps are listed in manufacturers' catalogues,
most distributors only normally stock 63V and then 100V.
63V is adequate for your application although you may need to spec a higher
voltage to make it big enough !
You should be looking at which manufacturer meets your dimensions really.
Modern caps have shrunk a lot due to developments in materials.
Screw terminal types are rare these days btw. Most ppl pcb mount.
Check out www.farnell.com
Graham
G
Guest
Guest
> $33 each
Ouch !
Graham
G
Guest
Guest
On Fri, 22 Oct 2004 00:07:00 +0100, Pooh Bear
>Why ?
>What reason ?
So he can persuade himself it sounds better ? :)
