6870 Problems with stuttering and lag spikes
In every game I try to play, the game always runs smoothly for about two seconds and then the fps tanks to about 5, but then it goes back to normal and stutters the whole time. The only game where this didnt happen is Battlefield 3. I have tried the driver solutions, but I cant figure out the problem.
These are my specs:
CPU: Phenom x4 965
GPU: Asus HD 6870
RAM: 8 gigs
Motherboard: M4N68T-M-V2
Display: Sony HD TV
5 answers Last reply
More about 6870 problems stuttering spikes
  1. It sounds to me like your 6870 is stuck at 2D clocks.
    There are three different steppings for a card:
    Idle (I think that's 100/150 for the 6870), 2D (Web browsing, videos) which are around 400/500, and 3D which is the full clock speed.
    My old 6870 would always stick at the 400/500 clocks, which was really annoying. It's a driver problem, and has to do with Power play.
    If it isn't too much trouble, can you download an application called GPU-Z, install it, and then tell me what the clock speeds are when you run a game? That would help see if this really is the problem.
  2. It says my clock is 955. I don't know if this is relevant or not, but my load is at 30 when I play games.
  3. sounds like heat, something is overheating and throttling back. also, reinstall your display drivers, donwload the latest from amd website,.
    I just did a clean install of drivers again, but everything is still the same. The temps on both gpu and cpu never passes 60 degrees. Also, when the frame drops happen, my gpu load goes to 0.
  5. I got the same problem, did you got any solution?? :(
    every game lags... even in worse quality
Radeon Games Graphics
