HD 7950 graphics card problem or HDTV issue ???
ankurdabas
18
i was playing nfs mw 2012 on my rig ,,
then due to some urgent call i closed it directly by pressing alt + f4 ,,
then i saw that the display was full of glitches,, like millions of vertical lines and the screen was working too
it goes away whenever i change the resolution or turn my hdtv off and again turn it on ,,
so my ques is what is this ???
a gpu malfunction ?? or tv ?? one more thing ,,,, m using hdmi ...
help plz :pfff:
Depending on the resolution of the game and resolution of the windows desktop, it could just be a synchronizing problem that was solved by turning the HDTV off and back on (this forces a resynchronization handshake between the PC and HDTV).
Monitors that were designed for use by a PC resynchronize quite often, an HDTV usually only sends this synchronization signal during power on/off and HDMI plug inserted/removed.
ankurdabas
18
one word for you ..... genius ..... ;) ;) ;) ;) ;) ;) ;)
luv u man ... dis fully make sense ,,,,
now m like ,,, :bounce: :bounce: :bounce: :bounce: :sol:
