Yes No
Ads
Tom's Hardware > Forum > Home Theatre Legacy > Ptv Tivo > DirecTv needs to turn up the quality control
Forum Home Theatre Legacy : Ptv Tivo DirecTv needs to turn up the quality control
Archived from groups: alt.video.ptv.tivo (More info?)
I have a [new] DirecTV tivo box & a high end Sony direct view tube tv.
It seems the weak link in picture quality these days is that DirecTv is
spreading its bandwidth (for lack of a better term) too thin.
I know that they take a look at each show & based on the amount of
action in the show turn the meter up or down so to speak. A talk show
for instance with little movement on screen requires less than a football
game where there is much detail a fast action movement.
This problem is VERY APPARENT on show with dim lighting (night scenes)
or where the show is presented in letter boxed format with black bars at
the top and bottom of the tv picture, which is becoming more common
these days. You see pixilation and squirmy distortions.
The only shows with a decent picture are the Pay Per Views.
--Phil--
-------------------- http://NewsReader.Com/ --------------------
Usenet Newsgroup Service $9.95/Month 30GB
Reply to Phil
> --Phil--
You're not the first to say so. The only sad think is that the cable
companies do the same thing or worse, even though they have a lot more
available bandwidth. I guess they want to make sure they get you that
sixth home shopping channel.
Randy S.
Reply to Anonymous
> Randy S.
You are right. When i had digital cable from comcast, the compression was
much worse than directv but when i had digital cable from time warner cable
in milwaukee, it was very nice and clear. Each area and provider is just is
different.
Reply to Anonymous
Had both Directv and Dish for a year in 2003. I perfer Dish . Dish has
a more uniform picture and it seems to hide any flaws in the back
grounds better. With Directv the picture was sharper for closeups on
the faces but the backgrounds pixelated, and had more macroblocking
etc. Drove me crazy. Dish has been accused of being a softer picture
but I like it. It depends on what you are used to and what you perfer.
MikeD-C05, Posted this message at http://www.SatelliteGuys.US
Reply to Anonymous
On 16 Mar 2005 03:50:27 GMT, Invalid_Email@dot.com(PHIL) wrote:
>A talk show
The data compression on Sunday Ticket is terrible too by the way.
During football season they have to run the regular channels and all
the football games at the same time and they compress even more! Only
the HDTV games are watchable. The SDTV versions are really, really
bad.
Reply to Anonymous
"Ohiyesa" <ohiyesa@sbcglobal.net> wrote in message news:1111163332.5ebb7444bda2d631e54f0a8b3a11312e@teranews...
> >A talk show
> bad.
None of the local channels on the spot beam transponders is affected
by NFL ST broadcasts. Only the channels sharing transponders with
NFL ST channels on Sundays can be affected by football programming.
BTW, most of the dynamic shopping channels are not available on Sundays.
The "dynamic" channels are those that don't broadcast 24 hours each day.
Reply to Anonymous
On Mon, 21 Mar 2005 12:02:13 -0500, Sean wrote:
> On Mon, 21 Mar 2005 11:53:50 GMT, Jack Zwick <jzwick3@mindspring.com>
> wrote:
>>Exactly why I gave up cable and went to DirecTv.
> Hopefully it's not raining. Otherwise you're wondering if any channels
> at all will be on.
Wow... maybe we've been giving Sean too much credit. For a while now, I've
assumed he knew better, but was just a troll trying to provoke anger or
somesuch.
But, now we can see that he has been brainwashed by his cable company to
the point that he actually _believes_ in the "rain fade" myth.
Poor guy.
Lenroc
Reply to Anonymous
I don't know why you call "rain fade" a myth; over the past 4 years of
DirecTV watching I've maybe had a total of 4 hours of programming
affected due to loss of signal (or extreme pixellation due to drop out)
because of rain or snow. One program didn't record at all, due to loss
os signal during a heavy snow storm.
My normal signal is over 90% on 31 of the transponders (100% on one of
them), and at 60% on the spot-transponder for a region I don't get, so
it's not a setup issue.
Rain fade is a fact. However, it's nowhere near as bad as people make
out; 4 hours spread over 4 years is pretty good going! DirecTV is one
of the most reliable systems I've seen.
Stephen Harris
usenet@spuddy.org
The truth is the truth, and opinion just opinion. But what is what?
My employer pays to ignore my opinions; you get to do it for free.
Reply to Anonymous
My cable fades when it rains.
-MT
Reply to Anonymous
Rain fade is not a "Myth" per se, but it is defintely one of those
things that is perpetually overemphasized, probably at the urging of the
cable industry. The truth is, as you've noted, that it rarely occurs,
and even then only for short periods during extreme events.
4 hours of outage over 4 years is ((1-4/(4*365*24))*100) 99.99%
reliability, a number that cable only *wishes* it could even approach.
Part of that is not their fault, any idiot with a backhoe can disrupt
cable for dozens to thousands of customers. Unless you have an
intercontinental ballistic missile, it's tough for anyone to disrupt a
satellite source ;-).
When we suffered through 4 hurricanes down here this summer, we lost
power once for 3 days, and cable for 10 (I was lucky). I can't give
Satellite an advantage over cable for the first 3 days, since, unless
you had a generator, you weren't going to be watching TV anyway, but the
remaining 7 days Satellite had it all over Cable. I saw a lot more
Dishes sprout up in my area after that time.
We also ate a lot of melting ice cream ;-).
Randy S.
Reply to Anonymous
4 hours in 4 years is, from my calculations, 5 nines of uptime (99.999%).
My cable goes out more than that, and they can't even blame rain.
The myth is that Rain Fade is enough of a problem to not get DirecTV for,
not that severe rain can have an affect on the signal.
Lenroc
Reply to Anonymous
That's likely a wiring problem, most likely on your end. At some point,
insulation on one of your cables has worn thin, and when it rains, the
bare wire is finding a puddle...
That's what I've heard, at least.
Lenroc
Reply to Anonymous
(99.999%).
One of us is off a nine, I suspect it's me ;-).
Randy S.
Reply to Anonymous
- 0 +
On Mon, 21 Mar 2005 11:20:09 -0700, Lenroc
The myth is that you are not an ignorant gasbag.
Lousy sat reception is a fact. No matter how you want to downplay
and make excuses for it.
Sean
Reply to Sean
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
In article <LnE%d.42885$3z.1411@okepread03>,
When I first moved to Las Vegas, you could count on the cable going out when
it rained like you can count on the sun rising in the east. The whole
network was replaced a few years ago to enable things like bidirectional
cable-modem service. As a side effect, rain doesn't bother the new network.
_/_
/ v \ Scott Alfter (remove the obvious to send mail)
(IIGS( http://alfter.us/ Top-posting!
\_^_/ rm -rf /bin/laden >What's the most annoying thing on Usenet?
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (GNU/Linux)
iD8DBQFCPy2UVgTKos01OwkRAlCuAJ9nhRbQZkySsYCHerjJ1+rKHmx7CwCghFKL
pPtpYbFfiMSTRSsGNMCnyio=
=g3AC
-----END PGP SIGNATURE-----
Reply to Anonymous
"Mike Tyner" <mtyner@mindspring.com> writes:
I used to have cable rain fade, too, since my provider (Adelphia out
of Springfield, VT) was getting most of their content from various
satellite feeds. All-in-all, that setup was the worst of all words:
rain fade, digital artificting, *and* horrible analog noise.
Richard W Kaszeta
rich@kaszeta.org
http://www.kaszeta.org/rich
Reply to Anonymous
salfter@salfter.diespammersdie.dyndns.org (Scott Alfter) shaped the electrons to say:
Heh - this reminds me of an old work war story:
http://www.livejournal.com/users/z [...] 75851.html
-MZ, RHCE #806199299900541, ex-CISSP #3762
<URL:mailto:megazoneatmegazone.org> Gweep, Discordian, Author, Engineer, me.
"A little nonsense now and then, is relished by the wisest men" 508-755-4098
<URL:http://www.megazone.org/> <URL:http://www.eyrie-productions.com/> Eris
Reply to Anonymous
I've had DirectTV since it became available in my area.
I was the second person in line at Circuit City the very first
day it became available. So for years and years and years,
and I doubt I've even had 4 hours of "rainfade" total in all those
years.....
Ric Seyler
Reply to Anonymous
The puzzle of Sean's personality is becoming much clearer...
We've known for a while that Sean is bitter because he can't get his TiVo
to work right (he complains that he had problems with it changing channels
on his cable box, a 'problem' that most don't have, and the few that do
can fix it with a few minutes of effort). So now he's against TiVo, trying
desperately to justify his non-investment (more like rental money down the
toilet) in the Cable Co's DVR.
Apparently, he's similarly against DirecTV because he couldn't get good
reception. I wonder, was he too cheap to pay someone $20-$50 to come point
the dish? Or maybe he used the dish for target practice and then
complained about reception?
He's bitter, because he knows that DirecTiVos are better, but he's already
given up on them because of his "lousy reception".
I can empathaize, Sean. I want DirecTV, too, but I have no view of the
Southern sky from my location. But I didn't get as spurned as you... I
haven't fallen to the depths that I'm willing to use a Cable Co DVR. I'm
very happy with my Standalone TiVo, and I think you could be too, if you
gave it another shot.
Or, put another way:
Sean, "Lousy sat reception" is another Cable Company myth. I know you are
a Comcast Rumpswab, but you're losing what little credibility you never
had by parroting their sales bullets.
Lenroc
Reply to Anonymous
Lenroc (lenroc@NOSPAMFORYOU.hotmail.com) wrote in alt.video.ptv.tivo:
My local Comcast has no problem blaming the rain for their outages. Their
underground wires are of such poor quality that a good soaking will short
out entire neighborhoods...over, and over, and over. I regularly asked
for (and received) money off my bill because of day-long outages. As
soon as I moved out of an apartment, I got DirecTV and never looked back.
Jeff Rife | "Space. It seems to go on and on forever. But
| then you get to the end and a gorilla starts
| throwing barrels at you."
| -- Philip J. Fry, "Futurama"
Reply to Anonymous
There are 1582 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Tivo series 2: can it be hacked to become a stand alone digital video
By konigsberg, 119 days ago:
Nope, nobody has ever done the work to get around the need to pay TiVo for the schedule....
Best offers
