first a lil about my self so you dont think im a dummy! I have 4 AA degrees and I'm self tough in electronics and computer repair! I've been in my local paper 4 times for inventions. I'm all so the worlds worst speller! so I recently to on a wifi satellite dish antenna project. Ive been fallowing http://www.engadget.com/2005/11/15/how-to-build-a-wifi-biquad-dish-antenna/ Guide. So here my question why do I have to use a N - connector. Why cant I just drill a hole into the 1/4 " thick black plastic the same size as coaxes cable use the center as the main attachment and the outer breaded wire solder to the copper sheeting that is epoxy to the 1/4 " thick Black plastic when done epoxy the cable in to the plastic rout it through the horn and out!
