Intermittent interruptions streaming netflix on a wireless connection; keeps reb
Last response: in Networking
If your blu ray player has a built in signal strength meter, try running it. It sounds like you don't have a good wi-fi signal. You may have to reposition your wireless router or blu ray player to get a better signal. Worse case, you can always hard wire the blu ray player if it has an ethernet port.
alexisd9025 said:
It sounds like possible Wifi signal problems... there might be interferance. So i ask you whats stuff you have set up close to the Blueray?
We have nothing close to the Blu-Ray. It seems we may have to hard wire it to the modem, however, that consists of running cable wire from the office to the living room. There is no option to moving this equipment anywhere else as the connections are only in one area of the room. Thank you for your response.
Ask the community
