Entry level audio test equipment
Archived from groups: rec.audio.tech (More info?)
Looking for recomendations for an entry level test suite of measurement
devices. Spcifically I'd like to measure distortion/noise and generate
signals. Devices with balanced i/o (where appropriate) would be ideal.
I'm good on a scope and meter. Could I do this for about $1k (used is
fine). I'm open to PC based or individual boxed units. If PC based
what are the options for data aquisition cards?
Thanks guys,
Brian
3 answers Last reply
More about entry level audio test equipment
  1. Archived from groups: rec.audio.tech (More info?)
    "Brian Allen" <brianwallen@earthlink.net> wrote in message
    news:t%7hd.13670$5i5.7989@newsread2.news.atl.earthlink.net
    > measurement devices. Spcifically I'd like to measure
    > distortion/noise and generate signals. Devices with balanced i/o
    > (where appropriate) would be ideal. I'm good on a scope and meter. Could
    > I do this for about $1k (used is fine). I'm open to PC based
    > or individual boxed units. If PC based what are the options for data
    > aquisition cards?
    The data acquisition card of choice is simply a good sound card. Got any
    idea what sort of residuals you are looking for?
    The software part of the equation might surprise you - its a freebie. I've
    done a fair amount of equipment testing using sound cards and various pieces
    of software for my www.pcavtech.com web site. At this point my software
    package of choice is the freeware Audio Rightmark program which google will
    point you at. It runs a whole test suite in a couple of minutes, noise, THD,
    IM, frequency response, and several different noise measurements.
    If you're going for residuals in the 0.01% range, then you might find that
    the M-Audio Audiophile 2496 will work for you. If you are headed in the
    0.001% range, then one of the Echo cards even the Mia, or the DAL Card
    Deluxe might be for you. If you are headed for where the air is rare, being
    residuals well below 0.001%, then the LynxTWO is the card for you. Even it
    will be within your budget. The Card Deluxe and the LynxTwo are full
    balanced in and out.
    If you use a sound card for a measurement device, then you will want some
    kind of input attenuator so you can work with signals at various levels.
    Easy does it for me - a high grade 5 K 2 watt AB type potentiometer.
  2. Archived from groups: rec.audio.tech (More info?)
    Brian Allen <brianwallen@earthlink.net> wrote in news:t%7hd.13670$5i5.7989
    @newsread2.news.atl.earthlink.net:
    These products work well, and you can use almost any soundcard you have
    sitting around:
    http://www.etfacoustic.com/SoftwareOverview.html
    http://www.speakerworkshop.com/SW/Feature%20Summary.htm (freeware)
  3. Archived from groups: rec.audio.tech (More info?)
    >>aquisition cards?
    Thanks Arny, Ive got two sound cards, an echo darla and an alesis AI3
    interfaced through an alesis adat edit card. I'll have to look and see
    how they perform.
    Thanks,
    Brian
Audio Devices
