Hello,
I currently have an AMD HD 5870 installed. I purchased an AMD HD 7850 as an upgrade. (New card is: XFX 7850 2GB "Double Dissipation"). I chose this card as it appeared to have the same power (wattage) requirements as current card while offering an improved performance.
I rigorously followed AMD's instructions for removing old cards and drivers and installing new cards and drivers, including using "DriveSweeper" in safe mode prior to installing the new hardware.
HOWEVER, the 7850 set-up is not stable. An error message appears ("display driver stopped working and has recovered"). The screen will go blank for a few seconds, then recover, but with the same message. Navigation is impossible because the mouse is locked up. Even CTR+ALT+DEL fails. This sequence will re-peat until the system fails for good and reboots (to a screen that offers "safe mode" or "reboot as normal", which DOES NOT reboot to normal!)
The card is seated properly. The power connections are seated properly. The system was problem-free with the 5870 installed.
Am I missing something? Any suggestions?
