Closed
HELP upgrading from a Radeon 6850
I am desperately trying to upgrade and get a graphics card in to my CPU. Cyberpower has been screwing me over for the last 3 months keeping me in video card limbo and I'm simply going to have to buy a new card. I want to upgrade from the card that came with the system (http://www.newegg.com/Product/Product.aspx?Item=N82E168...) which was a Radeon HD 6850. My budget is 150$-230$, but I have no idea what a good card is or how to determine what is compatible. Please help!!!!!!!!!!!!! :(
More about : upgrading radeon 6850
Related ressources
Best solution
Yes PCIe 3.0 is backwards compatible.
For $230 you should keep your eyes peeled for a Powercolor 7870 Myst. It features a Tahiti LE chip which means it's a crippled 7950 and at a $230 price point.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
you can also try to find the Sapphire version, the Sapphire 7870 XT. It is currently discontinued by NewEgg but it should just be a out of stock issue.
I'm extremely green in the computer world. I am currently searching for a place to purchase the Powercolor 7870 Myst, but what exactly does backwards compatible mean in this sense? Also, does the fact that----- GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card -----has 3 fans and the ---------PowerColor PCS+ HD7870 Myst. Edition 2GB GDDR5(UEFI READY-------has 1 fan, make a difference?
