Hi All,
I have intel i5
win 7 home basic
Nvidia 7600 gtx
2Gb Ram
and a LG flatron monitor
I downloaded the Complex mod for homeworld 2 and since have been having problems with my display. When I switched on the PC after playing complex for the first time, nothing happened, no power at all. I opened her up and un-re plugged stuff (after checking for power cut mind!) and she came back to life. hooray i thought...
So here is the problem, switch on, as normal, shows options to enter bios, can enter bios no probs. booting windows the screen goes blank quickly says something about D-sub 47 HZ then goes blank, then says going into power saving mode but the monitor power light stays on (stable not flashing) and various combinations of these and does sometimes go into power saving mode properly. I hear windows startup jingle, enter password though i cant see sh*t and hear welcome ping. Now comes the really odd bit, if I unplug the monitor and plug it back in once windows has finished booting *gasp* it 'works' I say with inverted commas, cos when I start any game the screen goes blank for a second every minute or so getting more regular, I turned down the brightness on the monitor despite my doubts it would do anything but it does make the blank spells noticeably less frequent but not as you guys say [SOLVED]
Any help would be greatly appreciated
I have intel i5
win 7 home basic
Nvidia 7600 gtx
2Gb Ram
